xbox360 and xfi platinum
18 Sep 2005
Bristol
Hi,
I have an xbox 360 and an xfi platinum with optical I/O box. I cant seem to get the audio working using an optical cable. Does any body have any experiance with this?
Thanks,
Adrian
run Creative MediaSource Go (maybe found on the pc's toolbar) ,
select product settings and then Creative Audio Console,
select SPDIF I/O and change the SPDIF input settings.
I read that 'SPDIF Bypass' works, but for me the option 'DTS SPDIF-in Decode' worked.
gl :)
Thanks Hector,
I only have default and SPDIF bypass as options, no DTS SPDIF-in Decode. If I go into the volume control SPDIF is permanently muted and I cant unmute it. Is that anything people have come across?
EDIT:
Solved it, it appears I have to have it set to default but I had to un-enable digital I/O before changing it. Cheers.
Adrian
