Xbox360 dead after update?
7 Oct 2003
i just turned on the Xbox360 and it told me that there was a software update available. it downloaded no problem then did a restart, however the screen is black and there is no sign of life? the machine sounds normal and the green light is on, just no screen?
what the hell is going on??? has this happened to anyone else?
It's possible it doesn't like whatever video settings it's now set. I think there's a button combination you can press on the controller to do a factory reset.
how do i do a reset?
just checked google and it seems i may be suffering from "video faliure". i noticed that the saturation on screen was flickering. this machine is less than a year old after getting a replacement from the red ring fault. these machines are sh!t.
where would i stand with warranty?
My mates Xbo has just died since the new update but his was a launch machine.. that i had already fixed once using the old bake method.
Not it just crashes on all games after a few mins. That new update has killed it :(
http://www.free60.org/
Dangerous Xbox 360 Update Killing Homebrew
On Tuesday, Microsoft has released an Xbox 360 software update that overwrites the first stage bootloader of the system. Although there have been numerous software updates for Microsoft's gaming console in the past, this is the first one to overwrite the vital boot block. Any failure while updating this will break the Xbox 360 beyond repair. Statistics from other systems have shown that about one in a thousand bootloader updates goes wrong, and unless Microsoft has a novel solution to this problem, this puts tens of thousands of Xboxes at risk.
It seems that this update is being done to fix a vulnerability already known to the Free60 Project. This vulnerability has been successfully exploited to run arbitrary code, and a complete end user compatible hack has been in development for some time and is planned to be released on free60.org shortly. It will allow users to take back control of their Xboxes and run arbitrary code like homebrew applications or Linux right after turning on the console and without the need of a modchip, finally opening up the Xbox 360 to a level of hacking as the original Xbox.
Because of the dangerousness of the update and the homebrew lockout, the Free60 Project advises all Xbox 360 users to not update their systems to the latest software version. The Project website at http://free60.org/ will provide the latest information on this ongoing topic, including the final hack software.
Free60 (www.free60.org) is a project that aims to enable Xbox 360 users to run homebrew applications and operating systems like Linux on their consoles. The effort is headed by Felix Domke and Michael Steil, who have a background in dbox2, Xbox and GameCube hacking, and who have spoken at various conferences about their findings. Two years ago, Free60 released a hack that allowed arbitrary code execution using a game ("King Kong Hack") as well as an adapted version of Linux, but this possibility has been disabled by Microsoft in subsequent updates of the Xbox 360 software.
Felix and Michael have repeatedly argued that game console manufacturers should open up their platforms to Linux and homebrew, similar to what Sony has done with the PlayStation 3.
Mine died last night with the 3 RROD. Did the update on Tues night and it crashed after 5 mins but came back on fine. Went to play COD4 last night and it died totally after 5 mins. Mine's a 3 year old machine that I've had fixed once already 2 years ago but mine's now out of warranty and I've got a new one on order.
Only plus side is you can now order an Arcade 360 pack for just £39.99 from a large UK distributor. Which is very reasonable. .and comes with HDMI port.
Mine did this (HDMI monitor said it was out of range or something!?!?!), left it for 5 mins and it sorted itself out, been fine ever since.....
