XBox360 - Ext HD, Minecraft maps
12 Dec 2006
What HD/Flash drive do you need to swap user maps between Xbox360's. One of the kids wants to swap maps and asked me for a drive. I dunno what to give him. Will a flash drive do, or a ext 2.5" drive? Should they be fat32/ntfs and does the size matter.
I'm not sure what one we have. Its has internal wifi and an internal drive. No idea which one though. (I don't use it).
A flash drive will do the job, iirc the xbox has to format it anyway so just make sure you havent got anything important on it, or possibly partition it. The xbox can only use 16gb of any drive anyway :)
The way that the save system works I would've thought that you could only use the maps if you are using the profile that created them? (If that makes sense).
I could be wrong though.
Cheers.
I'll let them figure that out. I just didn't want to waste a good drive on them if it wasn't needed. I have a few spare laptop drives, but I also have a older USB 2 16GB stick. I'll just give them that.
I've stuck clear of messing around with the Xbox till now. I'll have to set it up properly now though. I have a Gold code I need to set up on it also.
