Xbox360 question
22 Oct 2004
My xbox360 premium is gonna die soon so im gonna splash out for a new one. Question is how will i transfer my old saves onto the new xbox360 elite, cause i aint got a memory card will i have to buy one of them aswell.
With the memory card, it's not the fastest, and can be difficult as some saves won't transfer all that easily.
If you know you're going for an Elite for sure, you might be worth trying to get someone from here to send you the Transfer Cable so you're ready, as it's by far the easiest way to do it, and won't cost anywhere near as much as a memory card :).
If you get one from a shop, and they're friendly enough, they'll be able to transfer the data for you. Just take your hard drive with you.
I got mine done for free, but they may charge.
