Xbox360, using 2 monitors??
7 Dec 2002
Kent
Basically....
I I want to switch the output from the 360 between a TV and a monitor depending on the room I am in.
Switch boxes obviously switch between INPUTS to one common output. I need the otherway round.... one input to go to one of two outputs.
If I mofify a vga cable to allow the HDMI to be plugged in also..... what does the 360 do if it senses BOTH a monitor plugged in via VGA AND a TV plugged in via HDMI?
Thanks for info. :)
If you can connect both via HDMI and can have the cables plugged in permanently then I'd recommend one of these:
Link
It uses a tiny amount of power and doesn't require any switching at all.
I've just set one up with a V+ box and it works perfectly!
