23 Apr 2010 at 21:49 #1 doopydug doopydug Soldato Joined 18 Oct 2002 Posts 2,830 Location Fife Recently bought one of these from ebay - is there any way to check its a genuine one? It's working fine but the seller was from Hong Kong.
24 Apr 2010 at 00:22 #2 Vonhelmet Vonhelmet Caporegime Joined 28 Jun 2005 Posts 48,298 Location On the hoods Hologram?
24 Apr 2010 at 08:12 #3 Nismo Nismo Soldato Joined 17 Oct 2002 Posts 18,543 Location UK I would have thought if it worked, it was genuine. There's no way for 3rd parties to get a USB wireless device working on the 360, is there?
24 Apr 2010 at 08:17 #4 Vonhelmet Vonhelmet Caporegime Joined 28 Jun 2005 Posts 48,298 Location On the hoods Nismo said: I would have thought if it worked, it was genuine. There's no way for 3rd parties to get a USB wireless device working on the 360, is there? Click to expand... It can be done, if you use a chipset that the xbox has drivers for.
24 Apr 2010 at 08:32 #5 Nismo Nismo Soldato Joined 17 Oct 2002 Posts 18,543 Location UK vonhelmet said: It can be done, if you use a chipset that the xbox has drivers for. Click to expand... Ah right, crafty
