XBOX360 Wireless controllers - Do they work with any unit?
1 Dec 2004
S.Wales
I have 2 wireless controllers here from an older gen xbox, I have just bought an elite, will it work straight away with this? or will I need to buy some sort of dongle.
I didnt have a dongle with the old xbox.
They will work, you will need to sync them with the console by pressing the circle button next to the memory slots on the console, and then press the circular button on the top on the controller, next to the charging plug.
they should work fine after syncing them as above. Ive had my xbox for years now and my controllers work with my brothers newer one.
Simple answer: Yes :)
I thought as much although I got abit worried when I seen someone who was after a controller but had the dongle.lol
