xclio 1000-2000
MOAR FANS!!!!111
I don't like the fact that you don't get any internal shots of the cases. They're most likely heavy steel covered in bits of plastic. Not my cup of tea...
What the hell is going on there?
3 front fans and 3 side fans?
That will completley mess up the air flow and direction.
Why use 180mm fans? I bet they are going to be crappy and noisy and you cant replace them. Far better of with 120mm ones.
And where do your optical drives go?
More plasticy tackyness from xclio
