Xebec Keyboards in stock!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Xebec Stream-Line Keyboard - Black @ £14.99 inc VAT
Introducing the line keyboard range. The wired and elegant series which meet all of your office and home needs. All of our line keyboards each have a unique shape and design. Each keyboard also boasts an array of multi-media hotkeys, designed to make your computing experience more efficient and easy.
The Stream Line is our lightest and most elegant wired keyboard. At just 615g it is incredibly light. But just because it has a super slim design and low weight doesn't mean that it isn't robust. It also features a metal like frame and a very high quality polished finish. Just to make it stand out from it's wired competitors, it even has 12 integrated multi-media hotkeys. Which have an array of different uses.
- OS compatibility: Windows 98/2000/XP/Window7/Vista
- Working Temperature: 0-45 °C
- Keystroke Lifetime: 10 million strokes per key
- Multi-media quantity: 12 keys
- Colour: Black
- Dimensions: 405mm x 142mm x 13mm (LxHxD)
- Weight: 615g
- 12 months included warranty, extended 12 months after registering
- Features
- Soft silent keys
- 12 multi-media hotkeys in total
- 8 media specific hotkeys: Start Windows Media Player, Volume down, Volume up, Mute, Previous track, Next track, Play/Pause, Stop
- 3 internet specific hotkeys: Home, Mail, My favourites
- 1 general hotkey: My computer
- Plug n Play installation
- Connects to PC via simple USB cable
- Unique stream line shape
- Light
- Durable
- Ultra Slim design
Only £14.99 inc VAT.
ORDER NOW
Xebec-Tech X-Line Keyboard @ £18.98 inc VAT
Our x line keyboard is an ideal keyboard in the office or at home. It boasts 15 multi-media hotkeys. All with a different array of functions, some are responsive when you are web browsing, others whilst you are working with your music or videos and other media elements on your computer. The integrated palm rest ensures comfort whilst at work on the computer.
- Working Temperature: 0-45°C
- Multi-media quantity: 15 keys
- Weight: 810g
- Dimensions: 440mm x 195mm x 15mm (LxHxD)
- Soft silent keys
- 15 multi-media hotkeys in total
- 8 internet specific hotkeys: Home, E-mail, Previous page, Next page, My favourites, Refresh, Stop, Search
- 7 media specific hotkeys: Volume down, Volume up, Mute, Previous Track, Next Track, Play/Pause, Stop
- Unique X shape
- Light
- Durable
- Integrated ergonomic palm rest
Only £18.98 inc VAT.
ORDER NOW
Xebec Media Line LightWeight Keyboard @ £14.99 inc VAT
The Media Line keyboard is a true revelation. Not only is it extremely light- weighing in at just 760g with a super slim design and an integrated ergonomic wide palm rest, but it also boasts 18 multi-media hotkeys. Making fast switching between applications effortless, no longer need to run to the start menu to open an application!
- Multi-media quantity: 18 keys
- Dimensions: 450mm x 190mm x 13mm (LxHxD)
- Weight: 760g
- Soft silent keys
- 18 multi-media hotkeys in total
- 7 media specific hotkeys: Play/Pause, Stop, Previous track, Next track, Volume down, Volume up, Mute
- 4 internet specific hotkeys: Favourites, Refresh, Home, Mail
- 7 general hotkeys: Page up, Page down, Search, My computer, Calculator, Sleep, Multi-media start
- Unique super-slim shape
- Light
- Durable
- Super Slim design
ORDER NOW
Xebec HTPC/Console Handheld Keyboard @ £34.99 inc VAT
The htpc handheld keyboard is the ideal home theatre entertainment system solution. It is a mini keyboard with a whole host of built in function keys and specially adapted features.
The htpc handheld keyboard is the ideal controller for your home theatre entertainment systems. It is fundamentally a mini keyboard for home theatre use, ideal and specially developed for use with widows media centre enabled PC’s.
It is also compatible with Xbox 360 and PS3.
Connects with Android tablets running Honeycomb 3.1 and the latest Android tablets running Honeycomb, such as the Motorola Xoom and the Samsung Galaxy Tab 10.1 with the USB to micro USB adapter.
- 10-15m wireless range due to a 2.4GHz nano receiver
- 2.4GHz nano receiver fits into USB port of your computer
- Plug n Play installation- a specific driver is not required
- Built in gesture enabled touchpad
- Power saving On/off switch
- 13 media hotkeys
- 11 enhanced function keys
- Weight: 170g
- Dimensions: 163 x 121 x 28 mm
- 73 keys - 13 hotkeys (inlcluding 11 media hotkeys) and 11 further enhanced function keys
- 11 media hotkeys are: www, e-mail, back, forward, previous track, next track, play/pause, stop, volume up, volume down and mute
- 11 further enhanced function keys (activated via the "fn" key)
- 6 MCE hot keys: My music, my video, my picture, my TV, my radio and DVD
- Gestures on the touchpad include 2 finger scrolling
- Built in and ergonomically placed rear positioned left and right click buttons
Only £34.99 inc VAT.
ORDER NOW
Xebec iTouchpad Diamond Series Wireless Keyboard with Built In TouchPad - Black @ £34.99 inc VAT
A compact, wireless and rechargable keyboard all in one. The itouchpad diamond keyboard has a full Qwerty keyboard with a build in track pad on the actual surface. The keybaords sleek, light and thin design makes it ideal for portable and wireless use. It has a ten metre wireless range ensuring that you don't have to stay next to your computer at all times. When you need to recharge the keyboard, just connect it to the computer via the USB cable.
The itouchpad diamond keyboard has a built in mouse trackpad with right and left click capabilities resulting in no need for an external mouse. You can walk around the room when giving a presentation and navigate the page effortlessly, or if you are teaching in class you no longer have to be stood next to the computer at all times.
The re-chargable nature of the keyboard means that when you aren't using the keybaord, just connect it to the computer via USB and it will have plenty of battery for when you need to next use it. There is also an On/Off switch which can save power when you don't need to use it.
- The keyboard is plug n play enabled therefore there are no drivers which need to be installed.
- Apple numeric keys
- Full functionality of a full-size layout keyboard due to built in numeric keypad and 12 function keys
- Tilt feet for adjustment of the tilt angle for an absolute skid-proof and ergonomic operation
- Blue LED indicating pairing, transmitting and low battery
- Power On/Off switch to save battery
- Key count: 89
- Construction: Soft-Touch-Membrane technology
- Battery type: 2× AAA 1.5 V (included)
- Plug n play
- Re-chargable
- Optimal for Digital Living Rooms (HTPC) as well as for training, conference & presentation rooms etc.
ORDER NOW
Xebec iTouchpad Diamond Series Wireless Keyboard with Built In TouchPad - White @ £34.99 inc VAT
- Key count: 89
- Plug n play
- Re-chargable
ORDER NOW
Do any of the wireless keyboards have full-size number pads? Judging from the pictures, I'm going to say no. I can't make out if the last one listed does or not.
Nope the last 2 are the same, just one is black other is white.
Yoour on to a winner with HTPC keyboards.
There is literally not much on the market and those Keysonic ones are just shoddy (had 2 broke)
Might nip in to see the Xebec HTPC/Console Handheld Keyboard
Awesome,Like mentioned you dont see many of these type of HTPC style keyboards...glad you guys sell them as i do plan on setting up a HTPC sometime,The Xebec HTPC/Console one looks great!
Very good prices too.
do like the look of that Stream-line jobby, might be just the ticket to give me a completely black desktop set mhmmmm :p
to be fair the media line has soft touch keys... and in reality there's going to be a fair amount of similarity between qwerty keyboards :p
Well the Logitech S510 is end of life, and the Xebex is not. The Xebec uses totally different key heads too. Flat and very low profile.
I know :p
To be honest, how many ways to make a keyboard are there? Its a long slab with keys on it! They are all the same to one degree.
Thinking of buying the Xebec iTouchpad Diamond to use in a HTPC I shall shortly be buiding.
2 questions.
1) what kind of distance does it work
2) Could I use this (As I take it it is USB?) when installing the OS (Win 7 64) or would I have to use a PS2 keyboard?
Anyone got one, what is your views on it?
Thank you
