XenApp 6 mapping drives and C$
6 May 2009
In XA6, do you know if it's possible to map drives and C$ automatically on login?
e.g. Our test server is prs60, I have installed an app on 60 and all working fine. When I logon to Cloud desktop as a test user it launches server 53, then running the app from the start menu automatically runs the app on 60. However it fails because an I drive should be mapped and there should be some files in C:\Program Files (x86)
Launching Test server 60 works because the files are on the C: already. The drive is mapped through a group but mapping does not work on when logging in to a Cloud session for some reason. NativeDriveMapping key is set to FALSE as default so not sure where it's going wrong
Thanks
Think ive found the issue. In baseline ctx policies we have 'autoconnect client drives' and 'client drive redirection' set to disabled
