Hi all, I'm going to buy one of the pre build systems on pay day and I'd like to get some opinions please especially OC staff if they see this thread.
http://www.overclockers.co.uk/showproduct.php?prodid=FS-237-OK&groupid=43&catid=1444&subcat=1712
I'll be adding on an SSD and a 470 taking it just over £800.00
Or alternatively the:
http://www.overclockers.co.uk/showproduct.php?prodid=FS-025-OP&groupid=43&catid=1444&subcat=1712
As my budget is around £850.00 if I go for the Onyx, I won't be able to afford the 470 and the SSD.
Any thoughts from anyone please?
It's a big purchase for me personally so I'd really like to make the best decision. Is it wiser to just get the best core system I can and worry about GPU, etc later or should I go for something a bit more basic like the i3 setup with better accessories?
Just for further info:
I would be using the PC for gaming at 1920 x 1080, photoshop work and my current set up is:
Dual Core E6750 2.66GHz
4.00 GB of cheap OCZ RAM
Ati 5770 card
Asus PN5 SLI PLUS Mobo
Ati 5770 card
By the way, do the crossfire connecting ribbons come with the cards or do you need to order them seperately?
