Xenon lights and driving abroad
31 Oct 2002
Newcastle upon Tyne
Question for those who drive to Europe and have xenon lights.
What do you do with regards to beam adjustment? Do those stickers that you put on your headlights still apply or is there some way or adjusting them yourself?
Im pretty sure theres normally a lever on each light unit to change the beam pattern to the continental setting.
What I have on mine, although when I spoke to Honda about a friends Civic they said they were a flat beam or something so did not need adjusting which I thought was a bit wierd.
What happens to a car with Auto levelling Xenon’s, do these still have to be manually adjusted?
All xenons should be auto-levelling, but this has nothing to do with moving the beam for continental usage.
One moves the lights up and down, the other moves the projectors left and right.
If you have projector headlights (The beam angle thing is a projector v reflector thing IIRC, not a Xenon v non Xenon) which 99% of Xenon lights will have, there should be a lever/turny thing on the headlight unit itself. There is on mine.
Driver many times on xenons in France and have never bothered adjusting. Most of the driving was in the summer mind so lights mostly stayed off. Never been flashed though.
You're more likely to annoy the person in front of you rather than someone coming the other way.
On mine you had to remove each light unit, undo the back of the unit and then flip a switch so I would imagine its almost the same on the boxster.
