Thsi is just a general question thread really as i wont be able to do anything for a month or so anyway.I am wondering about building a dual core xeon machine for boinc etc. after seeing how cheap they can be had. Any suggestions about what speed processors to use, both for stock speed and overclocking? Most of the processors I have seen are either 3 or 3.4GH (E0 stepping i think)
I have also heard a lot of people seem to be using the Asus NCCH-DL board for overclocking. Does this board need special RAM or can you use normal stuff? I have had a look round but i cant find whether it does. Are there any other boards i should look out for?
What affect does RAM have on the crunching speed of the computer. I know about getting good timings etc for overclocking but does more RAM mean faster processing? Or will 512mb be just as good as 2GB on a pc that would run linux and boinc only.
I have a spare Hiper 580w PSU, if i used an adaptor to change the standard 4 pin to 8 pin would it be powerful enough to run a machine like this, ie amperage not wattage.
I was thinking of then just attaching a small (30GB) HD and a standard CD ROM drive for storage and loading up the pc at the start. The Motherboard above seems to have 2 VGA ports on it although from what i can see it doesnt have onboard graphics. Ill then use an old agp graphics card for the display if there are no onboard garphics.
Is there anything else i should know or anything else i would need (other than case and fans etc). Any help would be much appreciated.
