Hi,
My partner has just started her own interior design business and needs to invest in a small private render farm. She's asked me to sort the hardware and I've determined that for the software she uses (3DS max + VRay for final frame renders), a CPU-led render farm is the way forward. I'm thinking of building 10 nodes around Xeon E3-1245V3 processors, with 16 GB ram, 60 GB SSD, mATX mobo and Win7 pro per node. This will give 40 cores and sufficient performance for the work flow she anticipates.
Having never built a server before, I am a little unsure about the physical layout. I'm hoping to use 1u cases to reduce the space required (the E3-1245 has onboard graphics so there will be no pci-e cards to worry about). Do the stock Xeon processor coolers fit in 1u cases (do they even come with a stock cooler?) and if not what are the best options? Is there any reason to stay away from 1u?
Cheers,
Chris
Cheers,
Chris
