Xeon E5-2686-V4 Motherboard options
4 Dec 2002
Bourne, Lincs
Hi All,
Trying to find a motherboard for the above CPU, either ATX or mATX but my google-fu is failing
Any suggestions on which can be used?
Thanks
Assuming we are talking non ES/QS, then it’s going to work on any X99 or C610 board from memory, ATX is easy, MATX is is a little harder and ITX is literally 2 boards from the same OEM (ASROCK). Either way check BIOS support as being a V4, you will usually need a more recent BIOS than shipped originally.
If you get stuck then entry level e3 16xx and earlier v3’s are stupidly cheap, X99 boards seem to have been going up in price the last 6 months and dual stuff is pot luck.
