munge said:
El Jimben said:The Xeon is a server chip and is likely to be made from higher grade silicon and therefore should overclock beterr.
munge said:Only difference seems to be the bundled games!
Philio said:If you look around you can get them for a fair bit cheaper without the games too.
Blasphemy!!!munge said:You mean you can buy stuff from somewhere other than OcUK?!!!![]()
Yeh equivilent to Opterons.munge said:So same basically as the Opterons then? So why is it cheaper?
PinkFloyd said:Yeh equivilent to Opterons.
socket 939 Opterons were cheaper than normal AMD64s when they came out too iirc![]()
lay-z-boy said:Up until this morning i had mine in a rev2 evga 680i
gt_junkie said:I'd guess he must have upgraded to a new P35.![]()
Bito said:...
The true equivalent to the Q6600 is the Xeon X3220 (9x multiplier).
This costs coonsiderably more than the Q6600.
