Xerox 19" & Xbox360
21 Feb 2006
Southampton, UK
Hi guys, i'm having my xbox delivered sometime this week and was just wondering if i could, and how i could go about connecting it to my Xerox XA7-192i.
Now on the back of the monitor there are no extra connection slots, it's just got 2 cables coming out, one for power and one for DVI. So i'm confused as to whether i could do it or not.
Thanks for your help
if you could get a female DVI to female vga adaptor between your xerox and your hd vga cable(not component) then it should work theroetically... but some panels cant process an analogue signal(that of which an xbox 360 produces)
A vga box would definatley work.
Dont forget to get a xbox vga cable if your using a vga to dvi adaptor. The adaptor that came with your monitor wont work either because it will be designed to plug into a female vga d-sub.
