Xerox 22" Widescreen
23 Oct 2002
Cheltenham
Seems Xerox is joining the ranks of 22" widescreens
XM3-22W
Manufacturer XEROX
Analogue input 2 x D-sub 15-pins
Bandwidth 146.25MHz
Brightness 300 cd/m2
Contrast ratio 700:1
Dimensions 523.7 x 404 x 210 mm WxHxD
Display area 473.76 x 296.1
Display colours 16.7M
Horizontal frequency [khz] 30~82KHz
Lcd 22" WIDE TFT LCD
Max resolution 1680 x 1050
Panel surface Anti-glare
Regulatory approvals FCC, UL/cUL, CE, CB, TUV/GS
Response time 5ms
Speakers Yes
Vertical frequency [hz] 56~76Hz
Vesa mounting compatible Yes (75mm)
Voltage required AC100-240V~ 50-60Hz
Warranty 3Yr Manufacturer
Weight 5.4kg
I cant find it on the Xerox site but another retailer is listing it (where I "borrowed" the specs from) for £206 inc vat, Nice black bezel on it but it seems like yet another rehash of an existing pannel.
Does anyone know if the Xerox or Fujitsu 22 inchers support HDCP?
I'm thinking about getting a 22" widescreen to replace or use alongside my LG1980Q and i'd like HDCP support just in case. So far it seems to be a choice of the Asus and Saumsung screens.
Edit: Oops, i see that the xerox lists 2 analogue inputs and no DVI, so i guess that'll be a no then.
No neither of them to as they are use only Analog D-sub inputs. I would bear in mind though that the Image Constraint Token which makes HDCP work probably wont be included in any media till 2012 by which time I'm sure someone will have come up with a nice work around for it anyway.
just bought one of these yesterday, seems nice but i havent seen any other 22" wide screens to compare with.
Much better than my old 19" iiyama and better than the 19 samsung / lg's we use at work.
