Hey guys
I'm in the market for a car, been looking for about 2 months now and I had my heart set on importing a 2008 FX35 from Dubai but after doing some leg work I think it's probably just too much of a PITA.
Looking at the newer models here (2009+) I just don't think it makes sense given the cost and the relatively poor MPG.
Add to the mix that my brother just picked up a 2010 M3 4 door which I was driving around for the last week and I'm in love with it but I really don't want to spend 30k on a similar piece and frankly it's a little too powerful. I imagine I would get bored with it and then be left with something fairy expensive to maintain.
Now I'm looking at an A5 sportback (though I had issues with my A5 coupe in Dubai and swore I'd never touch one again yet I think it might hold up better in the UK than it did there), a Merc C or E or a Jag XF.
I'd want something reasonably nippy but it doesn't have to be M3 performance.
Budget is around 10-20k all cash and I'm looking for something very reliable, excellent quality and generally hassle-free. Looking at the XF's they appear to be on the upper end of that scale price-wise, but would you fellas recommend them? Is there anything I should be aware of given that I've never owned a Jag?
And finally if I do opt for an XF - what trim should I look for? They have the most confusing options I've ever seen. If not the XF, would there be something similar in the Merc range that would be overall better VFM?
