XF-I help
Most of those shots are of the Creative Volume Control. You should have an icon on the taskbar. Double click it.
EDIT: If you installed drivers without doing custom install then install again and do a custom install and tick the one where it says Volume control
Are you talking about the drivers on the CD or from the creative website? As the creative website drivers don't have a 'custom' option that I can see?
Just tried both of them beta and standard?
I have the same issue as Drizmod :confused:
Fanks!
I installed from the CD first and then updated using the ones on the net. The option to to a custom install is on the Cd but i cant remember having that option on the ones from the net. If you have a CD install from there first
Check out the Creative forums for further information. Maybe someone in there might be able to help you
Had a browse but people there seem to be asking the same thing but with no response........
I can wait and keep an eye out to see if it comes up somewhere in the future!
Thanks ;)
For some odd reason they wouldn't go in properly, reformated and i got all the stuff now thanx anyway.
