As the title says, I have a XFI Gamer PCI and a friend is offering me his PCI-E XFI Xtreme 7.1 for £20. I only have 5.1 surround sound, so i was wondering would that be a worth while upgrade?
If I'm not mistaken, that would be a downgrade.
Isn't PCI express faster then PCI?
xtreme audio? stay away, its a downgrade.
do they make a pci-e xtreme gamer then? you should realise my last post was a question by the way.
Nope, it wouldnt be an 'upgrade' to go PCI-E, a sidestep at best, if its either of these then go for it
http://www.overclockers.co.uk/showproduct.php?prodid=SC-058-CL&groupid=701&catid=11&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=SC-062-CL&groupid=701&catid=11&subcat=
If its this, then its a definate downgrade and by trying to charge you £20 as well he is ripping you off good style
http://www.overclockers.co.uk/showproduct.php?prodid=SC-052-CL
