- 10 May 2004
- Middlesex
Hey guys,
Got a bit of a problem.
I have an xfi xtreme music pci card and the add on allowing digital i/o which plugs into the card. I have used this before to plug my 360 in before with no problems.
Everything has been fine until I hooked my new TV to the digital in of my xfi, it worked fine for a while. Now basically I can only get sound out of the front left/front right and bass speakers.
If I click on the "default" button in the creative control panel everything is fine again, sound from all speakers but as soon as I change anything, ie volume control, bass/treble etc I lose sound in the centre and rear speakers again. It also disappears if I open a movie or something in VLC.
I've tried unplugging the optical cable but it doesn't make any difference so I'm not convince its anything to do with my TV.
Any ideas guys?
Thanks a lot.
Any ideas guys?
Thanks a lot.
