Xfire 6870 temps?
Can't see your pics!!!
Many people with Xfire just wedge a piece of plastic/card in between the two cards and that normally sorts it
only 60% usage and 80degrees is kind of worrying.
My 2x5770's go up to around 65-70 with 100% of load after 1 hour of MoH.
If you don't have a fan in your case side panel then I'd look at getting one if I were you, makes a huge difference when running crossfired cards.
Right,I have moved the lower card to the bottom pci-e slot on the MB,luckily I had a longer xfire bridge.
run a benchmark to compare with my original setup,thinking the bottom slot was slower.
On the left is the new benchmark,the right is the original.
Uploaded with ImageShack.us
