xfire messed up
15 Jul 2009
im xfireing 2xfx 4890s...but ive just noticed my screen has become discoloured with flicker.when i disable xfire its perfect..im running res 1680x1050 my 4890s ive run at stock settings no change ive tried newer and older drivers and removed old drivers no change ...im stumpped
swap ports for your monitor cable :)
Sounds silly, but it's meant to work.
found the fault didnt have to look to hard opened case started to take it apart first component....1 ripped xfire bridge...problem solved replaced and all is good in the world again
