Hi All,
I currently own an Asus EAHD5870 which until Battlefield 3 was working great, but I can't push run Battlefield 3 at 60fps on Ultra Settings. Can I achieve this by adding a second 5870 (Can I purchase any 5870 or does it have to be the same model/manufacturer), or should I look at replacing the gfx card.
My Motherboard is capable of running XFire or SLI.
Thanks in advance.
Thanks in advance.
It is on their site if you look for it or just google "Crossfire Compatibility Chart ". That way you don't set yourself up to bad information from people that don't do their research or never owned the product.
