Xfire Questions
30 Jan 2004
UK
Hi All
I have a bit of a problem or i think it is anyways. I am about to sell my 2405 to get dual 19" TFT's. And also get a Xfire Bord and X1900 XT-X and then a second in a month or two.
But i also wont to connect my 40" LCD to my pc but as you use the dongle for Xfire and that dongle has to go to the display for xfire does this mean that if i connect my LCD to one of the other DVi ports it will not be getting multi GPU graphics?? rather only using the one GFX card..
My LCD only has D-SUB so i will have to use a D-SUB to DVI or i could use a DVI to HDMI..
Thanks for any help
XD-3
has no one got any idea how this would work then? Really what i am wonting to do is have Dual 19" TFT's and also have my LE40R51B connected using a crossfire RIG.
But i am thinking becouse of the dongle then this is not possible? and having Xfire on just one 19" would just be over kill.
I think this was answered before, & the answer is you can connect 2 screens via crossfire, with a splitter you get with the master cards if i remember correctly. Gibbo posted this to someones query. Try a search of the forums for it.
