xfire questions
30 Nov 2007
when you xfire cards and you use msi afterburner, do the settings you set for fan control ( fan speed at certain temps ) apply for both cards ? ie they both spin at the same % of fan speed.
also
on ccc xfire is enabled and it is working as ive benched a few things, but on the 2nd gpu its showing a temp of 0 and activity at 0, is this correct, i have afterburner showing me the correct teps in the taskbar and OSD but just wondered about CCC's reading
update:- am i right in saying that the 2nd gpu disables itself when its not needed, clocks go to 0 fan goes to default, and only kicks in when needed, games benchys etc ( with fans speeds, clocks all to there desired speeds ) just read this on guru3D
