Hi guys, was considering getting a new graphics card for some time (previously had an 8800gtx) and finally bit the bullet and bought a 4890 (against my better judgment, as I have always been one for Nvidia).
After the initial issue of having to order a 6 > 8 pin power connector (surely it should either be included in the box or stated on the product description?!!?) I finally got it installed.
First impressions, are not good.
Downloaded and installed the latest 9.7 driver/ccc package from the Ati website, rebooted, but then after the reboot I loaded the catalyst control panel to adjust my settings, selected advanced, and then when it loaded up it just kept flickering.
By flickering I mean that it was like it kept changing between being the active window and not, meaning that I could not click on any items whatsoever.
This flickering happens whenever I try and use the control center and to close it I have to repeatably click on the cross to close the window.
Also initially I had this same stuttering in games and also slightly in windows?! but I then right clicked on the ati tray icon and changed ATI AI to always off, this seemed to resolve the game stuttering but not the control panel?
I have done a search but have not found the answer yet, anyone have any ideas?
Spec below:
E8400 @ 3.0ghz
4ghz ddr2
Vista 64bit
500w Tagem PSU
Spec below:
E8400 @ 3.0ghz
4ghz ddr2
Vista 64bit
500w Tagem PSU
