- 10 Feb 2011
My grphic card is a xfx 5770. In AMD Overdrive you can set the clock speed, memory clock and fan settings. The High Performance GPU is set to default 850MHz, High Performance memory clock settings set to 1200MHZ default and fan speed is set to unticked so the card does that automaticly. The lowest both GPU clock and memory clock can go to is 600mhz for the GPU clock and 1200Mhz for the momory clock and fan minimum is 20 and max is 100
Just to mess around with the speeds what the safe minimum this could go to. Yes thats right not max but minimum speed. Its all ready set by default to minimum momory clock but what the minimum could the GPU clock and fan speed be set to and still play games with out over heating the graphic card?.
