I've just started really trying to push this card to see what it can do, i have fitted ram sinks (had to mod one of them as the heat pipe go's directly over one of the ram chips) and moved the card to the bottom slot in the case because there is better air-flow (2* 140mm fan's built into my desk blowing cool air through the bottom of my HAF) it's only running @8x PCI-e but haven't noticed any drop in performance (only tried GTA4 so far)
i currently have the core @ 777 and the memory @ 1100 i can't increase the V's because the board has no support for this so what sort of limit can i expect to reach safely? i'm getting 35'c idle and 69'c fully loaded with OC profiles on afterburner 1.61 and enabled unofficial OC in cfg file
would also like to hear from others with the same board as mine (it's the AVP version with the centre mounted non full cover HS+Fan like the black edition one) and other makes also would also like to hear what sort of cooling you guys are running on these boards if you've upgraded as i'm thinking about doing the same soon
