XFX 8800GTX, will it fit ?
Sure will mate, you might have to take out the middle cage though. No biggie, you can put your hardrives in the bottom cage.
I got the exact same card, but in the Thermaltake Soprano case. In there it nearly fits (if it was just a mm larger, it would't fit). If your case is just as large or even larger than the Soprano, it should fit.
Yes it will. I had a PC in the workshop last week with the same spec.. You might just have to remove the middle caddy as already said. Personally, I left it out and put another 120mm fan for better system cooling.
Then I added 3 drives in the lower rack in RAID-5
Hmm, thats good that it fits, but a shame about the drive cage needing to go.
Planning on having 4 drives, so it isnt a major problem, was just wanting two in each caddy for thermal reasons.
