***XFX ATI Radeon HD 4850 512MB Just £78.99 Inc. VAT***
17 Oct 2002
Stoke
Featuring a full TeraFLOP of compute power, the XFX Radeon HD 4850 is true power player. The single slot design enables easy three- and four-way CrossFire assembly. Play the most intense games with a graphics card that knows how to conserve energy while delivering optimum performance.
- Bus Type: PCI-E 2.0
- GPU Clock: 625 Mhz
- Memory Bus: 256
- Memory Type: DDR3
- Memory Size: 512 MB
- Memory Speed: 1990Mhz
- Outputs: HDTV, Dual-Link DVI
- TeraScale Graphics Engine
- Unified Superscalar Shader Architecture
- Accelerated Video Transcoding (AVT)
- Dynamic Power Management
- 800 Stream Processing Units
- ATI PowerPlay™ Technology
- ATI CrossFireX
- DirectX 10.1 Support
- HDCP Capable
- Feature: TeraScale Graphics Engine, ATI PowerPlay™ Technology, ATI CrossFireX, - DirectX 10.1 Support
- Package Contents: DVI Adapter, HDTV Component Adapter, 6 Pin Y Power Cable
***EXCLUSIVE Premium Priority 2 Year Warranty***
In the unlikely event of your card failing within 2 Years, OcUK will replace your card with a brand new one, pending testing within our standard RMA/ testing terms and conditions (http://www.overclockers.co.uk/support.php)
BUY NOW
The 4770 part due to its manufacturing process is very hard to get hold of at the moment hence the price staying high.
Just a brilliant deal on the 4850 rather than the 4770 being bad value. ;)
