XFX ATI RADEON HD 5750 XXX 1024MB GRAPHICS CARD ONLY £99.99 INC. VAT
17 Oct 2002
Stoke
Got the UK's lowest price on this factory overclocked card which offers excellent performance as well as all the usual 5000 Series features.:)
XFX ATI Radeon HD 5750 XXX 1024MB GDDR5 PCI-Express Graphics Card @ £99.99 inc VAT
Now, more people than ever can experience real innovation in DirectX 11 gaming with ATI Radeon HD 5700 Series graphics processors. Loaded with advanced technology, these GPUs have the power and premium features you need for fully immersive gameplay. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first GPUs in this class to offer full support for DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Core Clock: 740MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4800MHz (Effective)
- Processing Cores: 720
- Bus Type: PCI-Express 2.0
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
***EXCLUSIVE Premium Priority 2 Year Warranty***
In the unlikely event of your card failing within 2 Years, OcUK will replace your card with a brand new one, pending testing within our standard RMA terms and conditions (http://www.overclockers.co.uk/support.php)
Only £99.99 inc VAT.
ORDER NOW
Would this be a decent upgrade on a 4850? Temps on my current card are far too high and in the current heat its idle temps are around 60oc and ingame ones up to 90.
No in a short answer, I class the 4850 more like a 5770.
So should I be looking at a 5770 or something higher? The price of this card is more within my budget however I'm looking to make as much use of the money I've set aside as I possibly can.
I understand, the 5770 falls between 4850 and the 4870, I currently use one 5770 but intend on buying another in the future and should see performance close to a 5850.
I imagine two these 5750 would be a decent setup but id just buy one card if that was going to the case.
