XFX Black Edition Pro 80 Plus Gold / Platinum Certified PSU Range
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Being 80 Plus Gold & Platinum Certified isn't just a name. The XFX Black Edition Pro are regarded as one of the industry leading power supplies for clean consistent power among many other features. Being able to fluidly provide power to your SLI or CrossfireX setup and being fully modular the Black Edition power supplies are the choice for gamers. The 1000W edition is "Platinum certified" which means that it has a 92% power efficiency.
There are all in stock at OcUK :)
XFX 1000W Black Edition Pro '80+ Platinum' Certified Modular Power Supply @ £224.99 inc VAT
Only £224.99 inc VAT.
ORDER NOW
XFX 1050W Black Edition Pro '80+ Gold' Certified Modular Power Supply @ £199.99 inc VAT
Only £199.99 inc VAT.
ORDER NOW
XFX 1250W Black Edition Pro '80+ Gold' Certified Modular Power Supply @ £245.99 inc VAT
Only £245.99 inc VAT.
ORDER NOW
If you are going to use near 1000W then the 2% efficiency advantage may well be worth the £25 upgrade from Gold. Look like quality PSU's for those with more GPU's than sense :-)
Am I right in thinking that Platinum is 90+? Also, does anyone have first hand experience of the noise levels on these PSUs?
EDIT: just found the answer to my first question.
Yes I do. They have a fan mode selector switch, the first mode leaves the fan on all of the time and only speeds up when needed (basically normal);
The 2nd mode changes it to actually turn the fan off when there is a lower load on the PSU and only turn on at higher loads.
So it is basically as silent as possible.
I highly recommend reading atleast this page of this review: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story2&reid=267
The review states that the fan actually only came on at 804.2W/903.1W (DC Watts/AC Watts) of load was put through it. (1000watt unit)
