- 10 Apr 2004
Got a weird one for you guys today.
Basically, if this card has only one monitor connected to it via any connector (HDMI, DVI, mDP) it will crash at idle (i.e. sitting at the desktop).
If two cards are connected, then it doesn't...
I *think* i've traced it back to the cards ULPM (Ultra Low Power Mode) which clocks it down to 100/300 when only one monitor is connected.
So if I boot with two monitors (this is on a fresh install of W7 x64, XP and OS X), it will boot up, run fine, I can game for hours.
Disconnect one monitor or start up with only one monitor, it crashes within a few seconds, I assume because, it's coming out of the ULPM and falling over in the process.
Given that I can repeat this over and over without fault, is the card buggered?
It's a week old, thinking of sending it back for a refund so I can find myself a reference card as the cooler, albeit quiet under load, is louder than my 4870 at idle, which defeats the point.
Thoughts?
Thoughts?
