Adjustable Mounting Brackets
Fixed Vertical & Horizontal movment for high stability.
Quick rotation feature to switch instantly between landscape and portrait modes.
Supports VESA standard monitors up to 24 inches each.
£300 for a chunk of plastic and metal. Extremely overpriced for what it is. You can buy THREE 1080p monitors for the same price as the stand itself.
None the less it does look quite good. If it was half the price at around £150 give or take. It would be seriously considered by a lot of people I'm sure.
IIRC you can get monitor stands similar to that for ~£100
Really! Out of all the things I would love to upgrade on my PC it would be a three monitor setup. Not necessarily for games. Just for sheer productivity. So much easier. Using desktop switches isn't all it's cracked up to be.
