- 15 Dec 2005
Told my old man to get this in his computer so he could play Battlefield 2. Only had it a couple of months and whenever we try booting his machine it beeps once as if it had completed it's post but then nothing comes up but a black screen.
When we reboot, the machine doesn't switch the monitor on and the machine gives one long bleep and then 3 short bleeps. I figured then that the graphics card is to blame, but after only a couple of months? I tried reseating the card to no avail. Will try and use another card to see if that works.
The card itself looks as if it is running properly as when I opened the side of the case to see if the fan on the card was spinning and it was.
Has anyone else had a fault like this with this card?
Cheers Abyss.
Cheers Abyss.
is that a Q-Tec?
& yes, cheapo PSU DO work otherwise why would shops like OcUK stock them. Problem is when they decide not to work! Most have been known to blow-up, though not a rare occurrence even on 'quality' PSU, at least they don't take the rest of the PC with them.
