XFX GeForce 9800 GT
9 Jan 2010
Birmingham
On the Nvidia site, it says it need 2x6 pin connectors for the 9800GTX+, but I can tell you that my XFX9800GTX+ 512MB only need/use 1x6pin connecter. So if XFX says it only needs one, the it only needs one.
The main reason why is XFX only need one 6 pin connector, I would image XFX's custom design PCB actually allows it to use less power, thus only need one 6 pin connectors instead of two for the reference PCB design.
