*** XFX GeForce GTX 260 XT "Core 216 55nm" 896MB GDDR3 @ £124.99 inc VAT ***
Suspended
18 Oct 2002
OcUK HQ
*** *** XFX GeForce GTX 260 XT "Core 216 55nm" 896MB GDDR3 @ £124.99 inc VAT *** ***
he XFX GeForce GTX 260 graphics card rips through DirectX 10 games at blazing fast frame rates and enables realistic physical motion and massively destructible environments with NVIDIA's new PhysX. technology. And that's not all, the XFX GeForce GTX 260 graphics card also supports extreme HD (2560x1600) resolutions, and gives your system the power of up to 216 multi-threaded processor cores, offloading the most intensive processing tasks from your CPU to your Graphics Processing Unit (GPU).
- Core Clock: 621MHz
- Memory: 896MB GDDR3
- Memory Clock: 2000MHz (Effective)
- Memory Interface: 448-Bit
- Memory Bandwidth: 111.9GB/s
- Processing Cores: 216
- Shader Clock: 1242MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2 Dual-Link DVI-I
- SLI Ready
- HDCP Capable
- DirectX 10 Support
- OpenGL 2.1 Support
- PhysX Enabled
- CUDA Enabled
- Card Dimensions: 266.7mm x 111.15mm
***EXCLUSIVE Premium Priority 2 Year Warranty***
In the unlikely event of your card failing within 2 Years, OcUK will replace your card with a brand new one, pending testing within our standard RMA/ testing terms and conditions (http://www.overclockers.co.uk/support.php)
Just £124.99 Inc. VAT
BUY NOW
