- 26 Jan 2009
- Amsterdam
So, seeing as I'm planning on grabbing one of these sexy new 7970's in the coming weeks, I figured I might as well tinker with my current 5850 for a bit. It's at stock speeds, everything as it was out-of-the-box shall we say.
Now, I will first state I've never had a problem with this card, but I figured I would run FurMark first just to see what state it got to. Lo and behold, it was idling at 65°C and peaking under load at 92°C! Checking around, this is a bit high - it should be in the 50-80 range.
The only solution I saw was some guy getting ridiculed for using "Auto Mode" on the fans. Time to bump up the fan I guess, so I set it to 80% and watched the idle temps drop to 48°C and under load after 10 minutes it seems to have leveled out at 84°C, a much better temperature I think!
My question though is "Is this normal?" Should I really be having to max out the fan manually to keep it in a decent temperature range? Bearing in mind that this is at stock speeds, I've not touched the volts or clocks yet!
