- 18 Oct 2002
- UK
I've got an XFX Pro 750W PSU currently and it works fine, bought it second hand, no problems there came in great condition and not noticeably dirty in anyway.
But the fan noise! It's noisy. Not a rattle, or a bad bearing, just general noisy fan+airflow noise. It's in a spacious case, with a split design so it is in its own chamber and not taking in hot air from a CPU/GPU either.
I'd like to replace the fan, I've done it before +am aware of the precautions etc. I don't think it's on a any rubber mounts so will do that at the same time too.
Just wondering what a good replacement fan would be, CFM/dB wise?
Need to check if its 120/140mm too.
