- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys!
I thought I would post about the XFX Power Supplies.
They are great units with a very reliable OEM behind them. If you want a quality great unit then look no further.
Q1. Well you may well ask who the OEM is?
Seasonic - for all the XFX PSU's. Unlike other PSU vendors even the entry level range is Seasonic.
Q2. What are the main differences between the ranges?
The 450w-850w Core Editions are none modular and 80 Plus Bronze rated. The Black Edition 750w/850w are 80 Plus Silver and Modular.
The Black Edition 1050w and 1250w are 80 Plus Gold and Modular.
The Black Edition 1000w is 80 Plus Platinium and Modular (only Platinium PSU that OcUK sells currently).
Q3. How reliable are the PSUs?
XFX offer a full 5 year warranty with ALL their PSUs so that is a good indication.
Q4. What makes these units reliable?
XFX use Seasonic who use only the best components to build the units. They also are made with one single, powerful 12volt rail to ensure the best source of power for your valuable hardware components.
Q5. How noisy is it?
Very quiet, the fan used is almost silent, and the unit has it's own built in PWM functionality to ensure that the fans speed is adjusted automatically depending on the load/temp of the unit.
Q6. Why buy an XFX unit?
As already stated a great 5 year warranty covers these products, including the entry level lines. XFX cover every wattage requirement for any system and being an XFX unit they look amazing. Our returns rate is also the lowest of any manufacturer/brand that we currently sell.
Here are a select few options within the range. Click Here for the full Range
XFX Pro 450W Core Edition '80 Plus Bronze' Power Supply @ £45.98 inc VAT
Unique, continuous EasyRail™ technology enables you to maximize available power and make set-up easy. Stack numerous power-hungry components without fear of crashing. It's also a perfect solution for hardcore gamers.
- 450W of continuous power at 50°C
- Tight voltage regulation (±5%)
- High efficiency operation up to 85% (80 Plus Bronze)
- Single, high power +12V rail (up to 53A/636W)
- High quality Japanese brand capacitors (105°C)
- Quiet 135mm ball bearing fan provides superior cooling
- Supports multiple high-end graphic adapters (NVIDIA SLI & ATI CrossFire Ready)
- Supports the latest ATX12V and EPS12V standards
- Active PFC with Universal AC input
- Energy Star 4.0 and RoHS compliant
- 5-Year Limited Warranty
Only £45.98 inc VAT.
ORDER NOW
XFX 850W Black Edition Modular '80 Plus Silver' Power Supply @ £122.99 inc VAT
The XFX Black Edition 850 watt modular power supply gives you the power you need with a brilliant combination of form and function. Giving more than just life to your PC, this power supply allows easy cable management with modular connectors which helps increase airflow. With tight voltage regulation and high efficiency operation up to 88% (80 Plus Silver) this power supply will give you exactly what you need to keep your gaming charged and ready.
- 850W of continuous power at 50°C
- 80 Plus Silver Rating
- SLI Ready
- Detachable Modular Cables
- Tight voltage regulation (±3%)
- High efficiency operation up to 88% (80 Plus Silver)
- Single, high power +12V rail (up to 70A/840W)
- DC to DC Voltage Regulator modules for +3.3V and +5V
- Solid polymer caps provide enhanced reliability and stability
- Supports multiple high-end graphic cards (SLI & CrossFire)
- Active Power Factor Correction
- 5-year Limited Warranty
Only £122.99 inc VAT.
ORDER NOW
XFX 1250W Black Edition Pro '80+ Gold' Certified Modular Power Supply @ £245.99 inc VAT
Only £245.99 inc VAT.
ORDER NOW
XFX 1000W Black Edition Pro '80+ Platinum' Certified Modular Power Supply @ £224.99 inc VAT
Only £224.99 inc VAT.
ORDER NOW
ORDER NOW
- SLI Ready
ORDER NOW
ORDER NOW
ORDER NOW
