iir they need 600+ but someone will be along to confirm I expect...
Should be fine unless you've got a case full of gubbins and are overclocking components.
The Corsair PSU should be fine to power the card without issue.
What is the rest of your system spec, you should at least get the system to start as it would not defect a over current without starting if the PSU was under powered.
But a few options below:
YOUR BASKET
1 x SuperFlower Golden Green HX 650W "80 Plus Gold" Power Supply - Black £67.99
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £53.99
1 x EVGA 600W 80 Plus Bronze Power Supply (100-B1-0600-KR) £53.99
Total : £185.57 (includes shipping : £8.00).
okay proably gonna get a little stick for this but currently running my xfx r9 290x in my second rig until my new case arrives, currently running 3570K ON A P8Z77I deluxe with a water cooling loop running and its all working off a corsair cx500 (until my rm650 returns from rma) so you shouldn't have any problem with your psu.
That's pushing it a bit there, but yeah it seems stable doesn't get as hot as XFX state i seem to get up to 80 degrees max, but then again that depends on how well your system copes with air flow etc.
It also depends on how you've set the profile up in CCC! With the case mod to my Parvum S2, i was getting 80c with no more than 60% fan speed which is perfectly acceptable.
