XFX Revo 64
20 Oct 2002
North West
Just installed this along with two Samsung 1TB F1 drives and I'm getting about 80mb/s raid 0 speed :confused:
Seems very low to me?
Motherboard is a Gigabyte DS3P965
Are you getting 80mb/s all the time or is it with small files/large files?
You'll get vastly different speeds depending on what the drive is actually doing.
Remember this thing is really a Raid 3 controller so you're not using it as what it is engineered for. I know it can do 0 but if you want Raid0 get a Raid0 controller. I use one for Raid 3 with 3x8oGB drives and it's so far caught two drive failures without losing a byte.
remember that this is a pci card, so you are going to be pretty limited anyways, you would be better off using a cheap PCIe card, if you do not have any sata mainboard connects left.
I'd agree with above, I'm using in Raid 3 with WD RE2's and I get around 80MB's with HDTach though that's twice what I can stuff across the network and it was very cheap.... so suits me just fine.
You won't get great rates with a PCI card, some use the later derivations such as PCI-64 to improve speed.
AD
