XFX XTR vs Superflower Leadex
18 Oct 2002
North Wales
Hi,
I've narrowed it down to one of the 2 above PSU's - both of the 750w flavour.
They both cost the same, and have the same 5 warranty as far as I can tell. The XFX is based on the Seasonic G series, which seems well regarded - and the Superflower also well regarded.
So, is there any performance reason I should go for one over the other? And which of the 2 is the quietest? The XFX has a 135mm fan, so in theory should be cooler and quieter - but I know that's not always the case.
Thanks
Ok thanks for that - LED light's aren't a massive issue but if the fan is better(135mm?) and the extra warranty is good sound. I knew the G2 was Superflower based but assumed it was the same.
