- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys.
We have a great PSU deal for you today!
XFX 750W XXX Edition Modular '80 Plus Silver' Power Supply @ £83.99 inc VAT
The XFX XXX 750 watt modular power supply gives you the power you need with a brilliant
combination of form and function. Giving more than just life to your PC, this power supply allows easy cable management with modular connectors which helps increase airflow. With tight voltage regulation and high efficiency operation up to 88% (80 Plus Silver) this power supply will give you exactly what you need to keep your gaming charged and ready.
- 750W of continuous power at 50°C
- Tight voltage regulation (±3%)
- High efficiency operation up to 88% (80 Plus Silver)
- Single, high power +12V rail (up to 62A/744W)
- DC to DC voltage Regulator modules for +3.3V and +5V
- High quality Japanese brand capacitors (105°C)
- Solid polymer caps provide enhanced reliability and stability
- Quiet 135mm ball bearing fan provides superior cooling
- Supports multiple high-end graphic adapters (NVIDIA SLI & ATI CrossFire Ready)
- Supports the latest ATX12V and EPS12V standards
- Active PFC with Universal AC input
- Detachable modular cables
- Energy Star 4.0 and RoHS compliant
- 5-Year Limited Warranty, subject to registration
Was £96.95 Inc. VAT
Only £83.99 inc VAT.
ORDER NOW
Was £96.95 Inc. VAT
ORDER NOW
