XG27AQDMG green hue / tint
3 Jul 2012
As per title, just picked up a XG27AQDMG and has a very noticeable green hue / tint across the display not sure if this is the norm for this panel or if i just have a poor example as to colour correct this i have to remove - 50 green which seems a bit crazy.
I have had this monitor for several months and have never seen this problem. The colours and picture quality have been excellent out of the box. Perhaps you have received a faulty panel?
I just had to send mine back as I had some odd lines appear on the screen over night. Did a firmware update, played a round with the new OSD options and then played a bit of Destiny 2. Then in the morning turned it on and there were strange lines across a couple of parts of the screens. So its gone back to whence it came, now the anxious wait for the RMA peeps to give their verdict begins... :(
I know most W-OLED screens have stronger green than QD-OLED but this asus I cant get on with, I have LG C2 and Alienware AW3423DWF to check against and every time I view the asus I can't help but see this green tint, I can remove most using either Windows colour correction or OSD tools but I have to remove a fair chunk of green just for me to be remotely happy so I will return and refund as I know its an issue for me. i also updated the firmware , no issues to report, kinda hoped it would help with the colour but I know that would be a long shot.
