XI FI Digital Out
19 Oct 2005
Chelmsford Essex
Hi all,
I'm having trouble with getting the digital to work with DVD in that it doesn't seem to work at all. It worked before my last build (typical) but I had all the settings and what I needed to do written down somewhre but they seem to have gone walkabout!!
I've got all the right cables I think I just need to set up the X Fi software and the DVD player software to correctly get going.
Would some kind soul please post their settings so I can mimic them and see if that works. I've got Cyberlink Power DVD but I can get hold of any other DVD proggies if you guys use others.
Oh I should add I'm running the Logitech 5500 Speakers
Thanks people
Paul
Turn off the built in decoder on the X-Fi options then set the DVD software to use S/PDIF. You may also have to open up Windows Volume Control, go to the advanced setting then tick 'Enable Digital out'
yup
with the newest driver i have to redo this each time i reboot the pc (fixing in next driver i hope)
yeah this bug in the new driver really annoys me its something so simple you think they would have realised before they released it. I hope we dont have to wait to long for a fix.
so does the SPDIF not work at all or just in this instance?
I was thinking of getting an SPDIF for my 5.1 speakers, unless there is no difference in quality from analogue?
ok i've tried this and I still can't get anything through either the optical or coax. It only works through the direct input with Dolby PLII Movie if that makes any sense. I'm sure I had it working through the Coax input before. Pretty sure the cabling is done ok, can there be anything else I may have overlooked?
No huge difference between analogue/digital, plus with digital you can't get 5.1 in games
