Hello to all
I have Xiaomi 11tpro I got from my friend and it worked nicely until it got into water but only for moment I don't know if this caused issue but I guess. So I somehow blew it off and dried it and it worked fine so I thought everything works fine.
So 2 3 days after that display started flickering yellowish and it turned off but the screen I think works since I tried to turn torch and it works using power key, I tried restarting and hard restart and I hear vibration but nothing on screen.
I tried all I could find and only thing that works is pushing or squeezing phone 2 3 x and it somehow shows screen again like nothing happened...
However this lasts maybe again 1 2 3 days or 3 4 h and again flickerIng happens. Also weird that happened is that battery was stuck ar 15percent, I tried opening it on the back and I saw that batter connector was loose and I connected it again and then all worked...but again flickerIng always comes and goes.
I am attaching video if you can see how it looks
I also used factory reset and it worked fine after that but again it happened
