Xiaomi Redmi Note 4X
26 Apr 2006
Hi looking to get a half decent cheap phone for my dad.
I am a bit useless with networks etc, can anyone confirm that this phone will work in the UK on Vodafone ?
Also whether they think it is worth £130 ?
Thanks
Xiaomi Redmi Note 4X 4G Phablet Android 6.0 5.5 inch Snapdragon 625 Octa Core 2.0GHz Fingerprint Scanner 5.0MP + 13.0MP Cameras
Main Features:
Display: 5.5 inch FHD 2.5D Arc screen
CPU: Snapdragon 625 Octa Core 2.0GHz
GPU: Adreno 506
System: Android 6.0 ( MIUI 8.1 )
Camera: rear camera 13.0MP with AF and flashlight + front camera 5.0MP
Bluetooth: 4.2
Navigation: GPS, A-GPS, GLONASS
Sensor: Accelerometer, Ambient Light Sensor, mavity Sensor, Gyroscope, Infrared, Proximity Sensor, Fingerprint Sensor
SIM Card: dual SIM dual standby, Micro SIM + Nano SIM cards
Network:
2G: GSM B2/3/5/8 CDMA 2000/1X BC0
3G: WCDMA B1/B2/B5/B8 TD-SCDMA B34/B39
4G: FDD-LTE B1/B3/B5/B7/B8 TD-LTE B38/B39/B40/B41 ( 2555-2655MHz )
2G and 3G will be fine, 4G may not as it's missing band 20.
Although I really can't recommend the 4X. For some odd reason Xiaomi decided to pick a SoC that is actually a lower model than the previous Redmi Note 3: https://www.xda-developers.com/xiao...ragon-625-soc-has-hurt-yet-another-successor/
Another comparison: http://www.gsmarena.com/compare.php3?idPhone1=8580&idPhone2=7863
The Xiaomi Redmi Note 3 is actually more worth the money. But again, the global version lacks band 20 so don't expect good 4G coverage.
What exactly will your dad be using the phone for?
I have the Note 4 Snapdragon Global edition. It has band 20 4g. Cracking phone, you won't get a better for the money.
